Thread: Rear end Question
12-20-2006 #1
- Dec 2006
- Wisconsin
- 67
Rear end Question
What is the difference between a flanged axle style and a hub axle style rear end? I've heard that flanged style axles shouldn't be used for road racing/ circle track racing. Anyone have any info on this?
Kal
66 GTO
12-20-2006 #2I'm assuming that you mean semi-floating axles and full floating axles. The semi-floating axles bear the weight of the car on the axle shaft itself, where the full floating axles only use the axle shaft to turn the tires. Full floating axles have 2 tapered bearings inside a hub on each end of the housing that bear the weight of the car and the cornering loads. This is what is used in NASCAR and other forms of racing where high corner loads occur. It is also used in the top alcohol and top fuel classes of drag racing.
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
12-20-2006 #3
Full Blown G-Machiner
- Nov 2004
- Roanoke, VA
- 515
A flanged axle would be the type that not only does the axle support the weight of the vehicle it retains the wheel and absorbs the engine torque.
A hub style is what I would guess some ppl call a floating style axle where a hub/bearing assembly supports the weight of the car and retains the wheel and the axle only absorbs the engine torque.
As far as which is better for road racing I'll let the experts chime in on that but be aware that should a flange style axle break then you will soon be minus a wheel/tire assembly (not good at any speed). Should a hub or floating style axle break the wheel/tire stay attached to the vehicle and the only thing you lose is the ability to transfer engine power to the road surface.GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Syclone
Tow rig
12-26-2006 #4
- Dec 2006
- Wisconsin
- 67
Thanks for the help guys!
Does anybody know of any good books on this subject?Kal
66 GTO
12-26-2006 #5I got one started, but haven't had time to finish it. I don't know of any other.
