      Katy,TX
      Wayne Due C4 alignment
      Anyone remember what caster setting they used on their Wayne Due C4? 72 Nova/69 Camaro.
      Auburn, WA
      Before we dropped the C4 IFS, we used around 8* caster...and I'm pretty sure Wayne used the same. Where are you at now?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Katy,TX
      Alignment
      Still working on the car. Haven't had it aligned yet. What toe and camber did you use with the 8* of caster? I've seen a post where a lot of caster pushed the wheel too far back in the fender opening. Did you have any issues? Thanks.
      Auburn, WA
      That would be true if the "intended" caster was say, 4*, and then you moved it to 8*...then it would move back a small bit. But if 8* is the design spec, then the wheel will be right where it should be.
      Again, using our previous specs, something around -0.5* camber and 1/32 to 1/16 of toe.
      Matt Jones
      Mechanical Engineer
      Aug 2003
      I think Silver is telling you the caster is designed in. We have put 6 in them no problem, wheel in the center of the opening.
      Katy,TX
      Sounds good
      OK, that sounds good. I've borrowed a hub gauge to get it set in the general area. Thanks again.
