      Holland, Europe
      Newbie tire size question
      Hi,
      I like to step up in rim size from 15 to 17 inch...
      Question is, is there any tire out there that's ~ 28 inch in diameter?
      Front wheels will be 17x8, I'm not decided yet on the rear but its either 17x9.5 or 17x11 (don't know if this will fit on an A-body without tubbing it).
      Also, I want a high speed rating (V or higher).
      I searched alot of sites, couldn't find anything, thought I'd ask somebody who actually knows their stuff LOL
      Nov 2002
      Georgetown,TX
      Nitto makes a 275/50/17 that is 28" tall. A pair of those and 17x9.5 wheels & you're good to go.
      Oct 2006
      Phoenix, AZ
      Most of the tire companies will have spec's and dimensions available online for every tire they produce. For instance, if you go to http://www.nittotire.com/tires_555.asp you can then click on sizes and specs, and you will be able to look at the installed specs of each Nitto NT 555 model tire, of course other tire models may have different sizes available, so browse around until you find what you're looking for.
      I know Michelin, BFG and Toyo all have these specs available on their websites. I've spent plenty of time mulling over these specs myself
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      May 2002
      Northern California
      tire rack has a full listing too...any particular reason for such a tall tire?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Holland, Europe
      Quote Originally Posted by MrQuick
      I have 275/60/15's on the back of my cuttie, and I like the overall size - it fills the wheel wells quite nicely.
      The rims I'm looking at don't go larger than 17', I guess that gives me a limited choice.
      I've already seen the 450 Nitto's... I have heard that those are good tires, but I would have liked it if there was something a little bit wider and with a little higher speed rating out there. Thanks anyway
      Nov 2004
      dayton ohio
      falken also make a 275/50/17 them and nitto were the only 2 companies i found this spring that also made a 255/50/17. didn't want to mix tire brands. there were a couple other manufacturers that made 1 size or the other but not both. go to tirerack.com and use their search for sizes. not all are listed, and if they sell a brand they can get any size that manuf makes. also got to each manuf website and search there. i spent many hours on the computer doing research before buying. i also wanted the taller sidewall to fill the fenderwells and look more proportional on my 73 firebird. sorry still mid build so no pics.
