Results 1 to 10 of 10
Thread: Disc Brake Upgrade on a G-Body
12-16-2006 #1
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
I'm looking for a better than stock upgrade on my front disc setup for my 79 Monte. What do you all recommend? Is there a particular kit from someone?
Also, is a spindle change really needed? I'd almost rather not change the spindle so that it doesnt interfere with the air ride Tech control arms I plan on using...
TIA for the help.
Tony
12-16-2006 #2A cheap way to get bigger/better brakes is to install 98-2005 2WD Blazer complete/loaded front spindles. They are a bolt operation. The only change you will need is a thread adapter to convert the female end of the brake caliper hose to fit the factory threads on the steel line at the frame.
This will give you a 1/2 inch bigger rotor and a much better 2 piston caliper with increased clamping pressure. No other changes are needed.
If you shop for the complete spindles at the local boneyard AND the boneyard is NOT familiar with this upgrade, expect to pay $100-$150 for the pair of loaded/complete spindles. If the boneyard is savvy and watches EBAY, expect to pay $300-$350 plus shipping for the same parts!
This is an nice, cheap, easy and big safety improvement for any G body car.
12-18-2006 #3
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
Well the yards around here will give you no deals. I'd rather spend the money and get a setup better than stock and I've the room with 17" wheels so I'm looking for a good kit.....
12-18-2006 #4brakes
Try the stainless brakes upgrade calipar and rotor its a two piston piece really helps the braking and is around $700
12-20-2006 #5The '78-79 g body's used smaller wheel bearings. I don't think there's a kit for them. An 80 up spindle fits the same, except bearing size. FRANK
12-28-2006 #6
Original Owner
