Results 1 to 13 of 13
Thread: I need carb help. Please!
12-03-2006 #1
- Apr 2005
- Bonney Lake, WA
- 135
Im trying to figure out the right carb. but the more I read the more confused I get. So what I m looking for is thoughts on the best choice for a carb. Im thinking 830cfm Holley HP with annular discharge or something from AED. But I just dont know. This is a brand new engine that has yet to be run. I plan on a break in and tune on a engine dyno so I am trying to get close. 383 small block chevy. 3.75 stroke superlight scat crank, 5.7 scat q light rods / splayed 4 bolt / all coated bearings / cam is comp cams 12-432-8 which is retro hydro roller 510, 520 lift 230, 236 dur 110 lsa. intake opens 35 closes 67. exhaust opens 78 closes 30./ Pro magnum hydro lifters / pro magnum 1.5 roller rockers / the new afr195 eliminator heads/ vic jr port matched and reworked from carb flange to intake runner roofs / I believe the combo should be safe to 6500rpm - 6800rpm?/ tko 600 5 speed manual/ lightweight flywheel/ 10 bolt rear/ currently running 3.08 but will be changed to 3.73 or 3.55/ Car is 67 camaro appx 3700 lbs/ it will be used 80% street 10% open road race such as silver state classic etc. bring on the carb combos so I can make a good decision. Im open on cost although would like to keep under $1000.00. Thanks in advance. Jay.
