Thread: HVLP Spray Gun
11-30-2006 #1
HVLP Spray Gun
I just bought a new HVLP gun at work for $30. We had some items in our marketing conference room that we auctioned off to employees. This gun was built in the mid to early 90's. It's never been used and still in the box. The only thing is that it's got the paint cup under the gun. The paint cup is pressurized. The kit came with the gun, paint cup, wall mount regulator and a large 40 feet supply hose(looks like a black water hose). The manual said this regulator supplies the gun with 10psi of heated air. I'm not sure where the heat comes from.
I've got two cheap gravity feed guns (not HVLP) I paid $60 each. One to spray primer and one to spray the door jams. I've never used a HVLP gun.
Has anyone ever used a gun like this one (pressurized cup HVLP)? I'll be ready to spray my 68 next spring and thought I may use this instead of buying another gun.
Thanks for any info,
Jim Vest
Gun info:
DeVilbiss JGHV-501
1.0 mm tip
11-30-2006 #2a 1.0 mm tip is seriously small, what kinda business do you work for and what would they have used this gun for????....I've never used particular gun (do own an accuspray HVLP with the pressurized cup, it's kinda scary to use) I use a couple conventional HVLP's to paint with both gravity feed Iwata's 1.3mm tip for color and 1.4mm tip for clear....the difference could be in the pressurized cup
all I can say is hook it up, buy some cheap paint and try it out...I know th accuspray I have takes alot of getting used to compared to a normal gun but they can turn out some really nice paint jobsMatt
1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
11-30-2006 #3
- Aug 2004
- Colorado
- 397
