11-30-2006 #1
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
Air Ride Tech users, in here Please!
What do you all recommend for a setup?
Im going with Shockwaves and a Coolride Rear, with the strong arms on both setups. Now here are my questions...
Gallon Tank size?
Line size?
Single Adj or Double? Pros and cons of each?
Anything else I should be concerned with?
TIA!
Tony
11-30-2006 #2I'm running shockwaves at all four corners, 5 gallon tank, and whatever their standard line size is--I want to say qarter inch, not sure.
Go double adjustable all the way. The tunability of the shocks has been absolutely key to ride quality on my car. Before I tuned the shocks out to my pressure settings, the ride was what you'd expect of most airbagged cars--choppy and loose. Now it's smooth, controlled, and composed under almost any situation. The only real advantage to singles is price.
12-01-2006 #3
Starting The Transformation
- Oct 2004
- Indiana
- 221
Originally Posted by Tony_SS
1. What are you putting this under?
2. Are you wanting a fast system or something moderate and controllable..... I am assuming from being in this forum moderate and controllable..
3. What type of driving are you going to be doing with the car?
12-02-2006 #4
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
Tony,
This is going under a 79 Monte Carlo.
I want something moderate and controllable.
I'll be doing highway and street driving. The ability for it to handle is crucial. Would like a tighter ride and feel, compared to a soft, sluggish, floaty one.
Would the Coolride setup be ideal in the rear? Or should it be Shockwaves..? if they are available for my app.
12-04-2006 #5The shockwave won't fit so well without some fab. work, so I would just stick with the CoolRide. We do offer a set of rear arms for the G-body as well. Just don't forget to upgrade the standard shocks to a set of adjustables.
Shockwaves up front with a set of upper and lower StrongArms.
A 3 gallon tanks would be sufficient, but if you have the room a 5 is nice. I would look at either the ARC4000e2 or ARC4000L.
12-04-2006 #6
- Oct 2004
- Indiana
- 221
yup exactly..... on that car I would run a 4100e2 or LevelPro..... definitely upgrade the rear Cool-Ride shocks to the adjustable shocks
12-04-2006 #7
Pro-Touring Veteran
- Nov 2006
- Washington, MO
- 2,363
Ok guys, how does this sound:
Front:
SKW1034DA-LUCA
Rear:
ARR21100-LUCA
And youre saying I shouldnt use the supplied shocks? What brand do you recommend for the rears?
And the Ride Pro
12-04-2006 #8We use the Varishock, just like in the front Shockwaves. Part # SHO1715DA
http://www.ridetech.com/productinfo/shocks.asp
