    Results 1 to 12 of 12
      lowering block problem with shock plate?
      i put in bell tech 2'' lowering blocks and the lower shock mount hits the rim? its a 9.5 17'' wheel
      69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
      http://hobbystage.net/camaro/jigga99/
      ....is that a question or a proposition?
      Stuart Seitz
      May 2002
      Southeastern WI
      Been there. I think I ended up buying lowering springs.
      Jeff
      May 2002
      Northern California
      ...either bell tech guy lost his tape measure or you got a real deep bs.
      spend the money and get de arched springs.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Fontana, CA
      Go for lowering springs. Besides, 2" lowering blocks is too much. It places all the stress on the long U bolts holding everything together. It's like raising a truck with 6" blocks in the back. Not a good idea! Any amount of power and traction will break something.
      Nick R.
      Chico, California Nor-Cal
      try this
      Try drilling the front leaf spring mount 3/4" higher. You will need to cut away the top of the mount to clear the spring eye. It takes time, but will lower car 1/2-3/4". Then use shorter block. You can cut aluminum blocks to desired size. This is done a lot on 2nd gens, but 1st gens work too. It also raises the roll center and dive charaterestics of the car, it should launch better. I would never use block bigger than 1", I did the above mentioned and then used 1/2" blocks, which eliminated the wheel hop
      Keith
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by ks71z28
      Keith
      Be carefull, that only works on 2nd gen F-bodies. There is not enough room on a 1st gen. Mounting the front leaf mount higher was invented by Herb Adams. When you read his comments on this mod, you will see that he already said it won't work on a first gen.
      May 2002
      Northern California
      ...oh really? heh, it can and has been done...tell Herb Mike's guys said hi.
      Quote Originally Posted by MrQuick
      w/o cutting into the floors?
      Central CA USA
      The second gen leaf bracket has a lower hole position compared to a first gen. I think it's about 1/2 lower, so the first gen has less room to raise.
      David
      May 2002
      Northern California
      Quote Originally Posted by neki67
      hehe ok, you got it...its not too bad. We just welded in a pocket for the spring eye to fit into.
      And its funny how a small change can make a big difference.
      thanks guys lowering springs is the way to go!
