      Connecticut
      Painting A Grill
      Hey Guys, i have a repo grill for a 68 camaro. i want to paint it black do i need to do anything more than just scuff it up with a scotch brite pad. Also what black would you use a gloss, semi gloss,flat, just wondering thanks.
      savannah,ga
      Wash it good in hot soapy water, Armorall, waxes, oil etc will mess up a simple repaint really badly. Scrub it with a nylon brillo or scotchbrite pad. Prime and paint. Think really clean before painting. I suggest semi-gloss or low-gloss. Either one will look good.
      Nov 2002
      Reading PA
      I used Satin Black on my 73's grille. Wash with soap and water and let dry thoroughly. I didn't scuff mine but using a fine Scoth Brite pad couldn't hurt, I'd do that before washing though.
      Todd
      67 RS/SS Camaro (FOR SALE), 73 Camaro, 15 Jeep Wrangler Unlimited Rubicon
      http://www.fquick.com/qwik1320
      Connecticut
      is there a special primer i should use on plastic or does it not really matter.
      thanks
      Mountain View, CA
      Just out of curiosity, is the material used in the grille for a 68 Camaro robust enough to withstand a powdercoating process? I'm pretty sure it wouldn't be, but was just wondering.
      True T.
      My blog
      Fontana, CA
      Quote Originally Posted by Damn True
      I don't know if the composition is any different, but the baking process may act like many years of use and make it brittle. I doubt it would melt it or distort it too much, but would definitely make it a little harder and brittle.
      Nick R.
      Nov 2004
      Colorado
      The part needs to be able to conduct. The powder is attracted by an electrostatic charge.
      Nov 2002
      Reading PA
      I didn't use any primer, just sprayed with Plasti-Coat Super Enamel.
      Todd
