      tulsa, ok
      changed water pump, now car is missing?
      I just changed the water pump on a 04 grand caravan with the 3.3ltr motor, and now the car is missing. took it to autozone to have the codes read, and it is reading cylinder 4 misfire...
      couple weeks ago i changed a water pump on a 99 cavalier, and it is having problems too: hard starting, cutting out, stuff like that...code stored in computer is cylinder 3 misfire.
      any ideas?
      chris
      68 camaro
      ls1 & 6-speed
      Feb 2006
      Elk Ridge, Utah
      Those Misfire code mean exactly what they are a missfire. ( I know thats not much help )
      Look for vac leaks ,Like a hose you might have left off.
      If the vac leak is in one runner then that will cause a single cyl missfire.
      If its not a vac leak then you need to check the plug (I have no idea how but is it cracked),check the plug wire, you could do the basics and check compression in that cylinder, If it is 100 lbs or less it wont run.
      I can only think you misssed a vac hose, the water pump has nothiing to do with how the engine performs (other than keeping it cool)
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Mountain View, CA
      Perhaps a ground?
      True T.
      My blog
      Dec 2003
      lost
      #4 is the front cylinder on the right side of the vehicle. 3.3/3.8 are notorious for corroded wires at the coil pack boots. Might just be a coincidence. The water pump on that vehicle about the easiest one in the world to change, I can't see you doing anything to cause the misfire.
      tulsa, ok
      thats what makes no sense, i did not undo anything on either car. i just thought i was kinda weird that both had the water pump changed and now both have pretty much the same problems.
      chris
      68 camaro
      ls1 & 6-speed
      May 2002
      Northern California
      agree also check for carbon tracking at the spark plug.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
