      california
      dse rear springs
      has anyone used detroit speeds rear springs and have you had any problems like no movement? :rolleyes5
      Oct 2003
      Arvada, Co
      If you have no movement my guess would be all of the bolts are way to tight.
      Brian
      california
      50 ft pounds at each spring eye the car is like solid no up and down
      Oct 2003
      Arvada, Co
      Not much can go wrong here. To find out for sure if it is the springs, take one out and lay it upsidedown on the floor and put weight on the center. If it moves the springs are ok. My guess would be your shackles. Speaking of shackles. Are they against the rear panel? If the are that would prevent them from moving.
      Brian
      california
      didnt think of that will look into that thanks
