Results 1 to 20 of 23
Thread: Crank Trigger for Pontiac 455
building a Pontiac 455 that i would like to put megasquirt EFI onto. i would like to control ignition off the crank, and am considering distributorless, using the EDIS.
has anyone put a 36-1 wheel on a Pontiac? where are they available, or who can make one?
who has done crank triggered EFI on a Pontiac?
thanks,
Scott.
11-16-2006 #2
- Sep 2004
- Kettering, OH
- 537
I converted my Pontiac 462 to EFI but went with a different ECU unit that allowed the use of a dual sync distributor.
MSD makes a crank trigger for the Pontiac. If the same works on a Chevy, it should work for you.1967 Firebird Convert, Fuel Injected 462 ci, TKO 600
12-21-2006 #3I think for wasted spark arrangement, I need the missing tooth type wheel with VR sensor.
Originally Posted by Hammered
12-20-2006 #4
- Dec 2006
- Los Angeles
- 334
Monkey, any luck sourcing a wheel?
12-21-2006 #5These guys sell one, but I'm not sure if it will fit. http://home.earthlink.net/~beanbooge...t_engineering/
They have specific dimensions listed on it, and I'm going to bring the dimensions into my builder next week to have a wheel trigger discussion. It's time to figure out the solution. The top end is getting assembled now, and I'll be ready to start tying together loose ends. I suspect we'll have to measure the preferred wheel size and have it custom made.
My other hanging chad is coming up with a solution for the plenum. I think I want to use an LS1 TB, but have not purchased a TB yet, so that's not for certain. Do you know of anyone selling custom type plenums that mount on a carb type manifold?
Where did you mount your wheel sensor? I think I want to fab something off of the fuel pump mounting holes.
Thanks, Scott.
01-08-2007 #6
- Dec 2006
- Los Angeles
- 334
I was going to fab an aluminum plate using the two pass. side bolts on the timing cover...actually the bolt and stud.
I haven't touched it yet, as I am working on brakes at the moment, front and rear.
01-08-2007 #7
- Feb 2006
- 478
You need to look at Allpontiac.com or Butler Performance or Kauffman Racing. Maybe even BOP engineering. One of those outfits should be able to put you on the trail of what you are looking for. I don't think the Chevy outfit will work on a Poncho, but these guys will be able to find you what you need.
02-21-2007 #8I recently installed MSII on my 427 Chevy engine using the EDIS ignition. I have an AutoCAD drawing of the trigger wheel, and a buddy wire EDM'd it out for me. I then made a bracket for the sensor that mounts to the front of the engine. I have the AutoCAD drawing if you would like it. You can change it to fit your installation. I set it up so it uses the 3 pulley bolts. It wasn't the easiest, but it was necessary. Also, Auto-nomics.com sells a throttle body that fits in place of a Holley or Q-Jet pattern for about $135. They will also add an idle air stepper motor and TPS sensor. Very good guy, and I am also happy with the products.
Ken
69 Camaro
427, 4 speed, TTII's, Konis, JL8 clone brakes, solid AL body bushings, some assembly still required
69 Corvette
427, 4 speed, TTII's, Bilsteins, HEI, what I work on while the Camaro sits
02-21-2007 #9
- Jan 2006
- Southern California / Maryland
- 489
