      Windham, NH
      Front Flex Lines Frame Bracket
      On a 1st Gen Firebird, the mounting bracket gets moved from the side of the frame rail to the top (not sure if this is true for Camaros too?) and requires a different bracket that looks like this:
      http://www.parts123.com/parts123/yb....Z5Z5Z50000136d
      ...I just need the one on the right.
      Anyone have a source for these? Classic industries wants $39.95 for the "kit" shown above and I would need 2. I am not cheap, but don't think $80 for 2 "L" brackets is reasonable!
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
      Newbury Park, CA
      What brake package are you using? If C4/C5 PBR then the hose routing is better using the side frame mount, not the factory disk brake top mount. I made mine from "L" angle.
      Windham, NH
      Quote Originally Posted by CarlC
      Newbury Park, CA
      I'm not familiar with the Wilwood brake line mounting location. Do you have an inboard or overhead photo?
      Windham, NH
      The hose fitting goes under the sticker:
      Feb 2006
      Elk Ridge, Utah
      Go to a 4X4 Shop and ask them if you can ask a tech for some.
      I used to work for a 4X4 fab shop and we'd get all kinds of extra gooodies like that lyin around
      And they will be zinc or cad plated to boot
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Newbury Park, CA
      IMO the stock drum brake and/or another bracket that allows the flexible hose to attach vertically from the bottom is the best option. If a horizontal attachment is used there will be a lot of tight bends, vs. a simple "U" with a bottom mount.
      Mar 2003
      Kirkland, WA
      Try inline tube, they have an assortment of mounting brackets, fittings, and clips.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
