    Thread: Engine Gurus
      Henderson,NV
      Engine Gurus
      Which Chevy big block combo would you go with for the street? A 489 or 496 stroker or a 502 crate with ported heads and larger camshaft.
      489&496
      Dart Heads and intake
      roller solid camshaft
      Gen 6 new block
      Scat cast steel crank
      502
      Stock GM crate short block
      Stock aluminum ported heads and different springs and seals
      Crane solid roller camshaft
      Edelbrock Victor junior intake
      The 489 or 496 can be built a little cheaper and looking at 570-590 horse and 600-620lbft. The 502 would be 625 horse and 600 ft lbs.
      I have heard the stroker has better manners and drivability than a GM 502 due to the longer stroke. I have to figure out what motor to go with shortly and would like you opinions.
      Nov 2004
      Colorado
      Put a stroker crank in the 502. There is no substitute for CID.
