      Apr 2003
      chbg, pa
      60 Impala fitment ?
      What will fit on this car with out any cutting?
      I am assuming that 18x10s and 20x10s would be the ticket. any ideas of backspacing and tire size?
      Oct 2005
      Olathe, KS
      TTT! I'm curious, too. I'm putting 20s on my '64 Impala and it seems like there's very little info on early B-bodies out there.
      -Chris
      '64 Impala Sport Coupe- Slow-Touring project; LR4, 700R4, work in progress
      '66 Corvair Monza Convertible- 110, Powerglide
      '95 Z28- 355 LT1, 76mm turbo, built 4L60E, 12-bolt
      '98 S10 scsb- 4.3 auto
      '00 Corvette coupe- 6-speed
      Jun 2006
      Indianapolis,IN
      Hey Guys I think I can help you out on the Impala Questions.59-64 Impalas use the same x frame.Wheel base on the 58-60 are a little differant than the 61-64. But as a hole preety much the same. On the rears you can run up to a 22.But most common is a 20x10 with 5.5 b/s if your running stock brakes and 5.75 b/s if your running aftermarket disc. set up.
      20x8 or 20x8.5 use a 255/35/20 4.75b/s
      20x10 use a 275/35/20
      275/40/20
      295/40/20
      front I would not recommend a 18x10 it will rub on the inside frame rail.18x8 is common but I have seen a 20x8 run in the front or even a 19x8.b/s on the 18x8 would be 4.5 standard brakes or 5 with large disc.as far as tires go on the front most common is 245/40/18 or 235/40/18.I you need anymore help give us a call Im sure we can help you out.Hers a pic of the car were doing now.hope this helps Tim
