    Thread: LT1 Information
      Oshawa ON
      LT1 Information
      I have been bitten by the pro-touring bug. I sold my old carburated 350 and bought a 96 LT1 with a 4L60E.
      I now need to find a complete schematic for the set-up. I need to set up the ignition as well as figure out something to do for a speedo.
      If anyone has info it would be greatly appreciated.
      Nov 2001
      St. Cloud, MN
      The 95 & 96 are different, ODB1 and ODB2. I would recommend you get the manuals for a 96.
      I would suggest getting an aftermarket harness. I used a Painless harness and it worked GREAT!
      Jon
      71 Nova LT1/4L60E
      Oshawa ON
      I think I have the wireing part figured out. I bought a Haynes manual. It has a good schematic in it. Being an electrician I just cant bring myself to paying that much money for a wiring harness, when I have most of it already.
      What do I do with the pollution control systems on the motor? Do I keep them and be green friendly, or will I gain much HP by removing it? How much can I remove of it without getting trouble codes?
      Nov 2001
      St. Cloud, MN
      If you get a program like LT1 Edit or TunerCat (i have) you can eliminate the lights from emissions things. Yours probably has 4 o2 sensors and I am pretty sure you can delete the rear two with programing. I am not sure if TC works with OBD2. You can also correct for tire/gear changes.
      Obvliously you will not want to remove any smog stuff if it is required where you live. You will not gain much power. I do not have any smog stuff. Air pump, egr, etc.
      I would recommend the programming message board over at cz28.com.
      Jon
      71 Nova LT1/4L60E
      Nov 2004
      You can run your motor on an OBD-1 unit. In fact OBD-1 is more user friendly and performance tuneable than OBD-2. There are a lot of people that convert '96 LT-1's to OBD-1 on the ImpalaSS forum. I would suggest calling or emailing Bryan Herter at www.pcmforless.com and he can help you with all the information you'll need to do it, as well as re-program the brain and delete whatever you don't want. Such as the VAT system, top end limiter, etc... , etc..
      Oshawa ON
      I have most of it complete now. I found out that the VATS needed to removed from the PCM. When I had the computer flashed I had the polution controls removed, some more performance into it, and the fans to turn on at a lower temp.
      The harness has not been to bad to modify.I removed all the polution stuff as well the a/c.
      I am trying to fit the computer under my dash but it is tight.
