Thread: Turn signal contact problems
11-03-2006 #1
- Apr 2005
- 18
I just intalled a tilt steering wheel. The turn signal mechanism and wiring is all brand new. When I signal right everything works correct 100% of the time. When I signal left it only works 40% or less of the time. I've traced the problem to the copper contacts within the mechanism. I cleaned the contacts as there was alot of grease on the assembly. I thought I had the problem solved but no such luck.
Has anyone else had this problem, and what did you do to fix it?
