    Results 1 to 15 of 15
      Quick Ford question....O.K. not so quick....
      Can anybody tell me what the last year a 351w was available? And would that motor drop into a 66 Mustang? And the big question.....What is required to swap from a 6 Cyl motor? Thanks in advance from a guy who nows nothing about Fords. Jason
      Orlando
      I know you could still get it in the 96 Fullsize Bronco.
      Chris
      67 Camaro single turbo LSX/T56 -V2.0 underway
      06 AMG CLS55 2.9 Whipple, 5.6 forged Darton MID
      06 AMG E55 w 63 conversion 2.9 Whipple
      99 FRC Corvette pretty in pink
      Jackson Ms
      96 was the last year. it will fit but headers are TIGHT.
      Chris V
      SOLD
      Fontana, CA
      Shoehorn: what will be needed to get a 351 in a 65-66 mustang.
      It is doable, I've done it, but it wasn't fun and maintenance is a royal PITA.
      Nick R.
      engine swap
      351w will fit, but is very tight.
      I believe the 6 cylinder mustangs had 4 lug wheels and lighter
      front suspension pieces -- you should definitely swap out for
      V8 pieces (or use the opportunity to step up to something
      like the coil-over swap kit from totalcontrolproducts.com).
      you should probably go somewhere like:
      http://www.vintage-mustang.com/
      to get more mustang specific advice. I'm pretty sure
      keeping the 6 cylinder suspension stuff would not be safe.
      Los Angeles
      -Tas
      '04 Mustang Saleen sc281 speedster
      '67 Mustang notchback: The fabled $500 non running project car: 308, auto, 2 barrel (now 4), AC(now removed), 5 lug, disk front, drum rear, power brakes and steering... that I got started and home for $65 :D
      Fontana, CA
      Quote Originally Posted by phonedude_mln
      This is also true. Car Craft is building up the suspension on a 6 cyl mustang right now and brakes are the next thing.
      Nick R.
      Heck, you can shoehorn a big block in there, but its a ton of work. It would be much more advisable to go the 302 HO route as parts are easy to come buy, its a very simple swap and the 289/302 are the same block. And the swap is a parts for parts swap, no mods, custom work or fabbing involved and if you know nothing about Fords, thats a good thing. And if its cubic inches youre looking for, punch out and stroke the 302, heck you can get 427CI out of 'em now. I have run a 6 cyl drivetrain with a V8, but its not the best idea. I never had any problems, but if youre looking in to serious HP and TQ, it could become an issue. You can buy everything you need out of a freakin catalogue! I have been building Fords for forever and they have always been 6 banger conversions except one, so if you have any questions, feel free. There is a TON of experise on this forum.
      Money, girls and cars...big ol' long cigars!
      1964 Mercury Comet
      90's 302HO, F303, Vic Jr, AFR 165's, 650DP, full roller, full MSD, WC T5
      18x8 245 up front, 18x9 275 out back
      KYBs, sway, 620 coils, stiff leafs relocated inboard
      13" Late Model Cobra Brake Setup
      I can list what parts you need and it all can either be bought from a store or junkyard find.
      1964 Mercury Comet
      I put one in a '65 Mustang years ago, an origional V8 car, headers were a problem, had a set of Hooker headers cut up and put back together, not sure if someone makes a set now. I do not think the 351W is worth the extra effort.
      The headers are the biggest problem and I do not believe anyone makes a set. They have to be custom made. And I agree its not worth the hassle.
      1964 Mercury Comet
      Feb 2006
      Brampton, Ontario, CANADA !!
      As an added note, a 351W with an aftermarket intake will not fit under the stock hood of a 65-66 Mustang, if that is a consideration. A nice 302 build-up is probably the easiest route, as suggested.
      BTW, the 351W was available in 1997 in the F-250 HD and F-350, last of the old boxy body style, but 1996 is the correct answer for the 1/2 ton trucks.
      cheers
      Ed N.
      Ed Nicholson
      73 VW Super Beetle "Sports Bug"
      95 Taurus SHO 5-speed -- new open-track beater
      So it looks like the 302HO is the way to go...glad I asked. Didn't know about the hood problems, but had heard the headers would be a tight fit.
      Quote Originally Posted by 64Comet
      If you wouldn't mind, I sure would be thankfull. Jason
      Feb 2006
      If you're after more cubic inches, there are a bunch of reasonably priced stroker cranks, and complete rotating assemblies, available for SB Ford engines now. 331 and 347 CID are common. Stroker, with a nice cam and a pair of AFR heads, will easily make 400+ hp.
      cheers
      Ed N.
      Southern Indiana
      big cubes for pony
      If i had my druthers i would look around for a 347 rotating assembly from a one of the Mustang racing venues. Team that up with some sweet AFR heads and a decent roller and retrofit cam (or later roller block which is better as it has 1 piece rear main seal) and World Products(I think) makes a block or some such company so you can make real world torque from a 289/302 size package.
      Honestly I really liked a souped up 289, wind like no ones buisness and still sip fuel when you cruise it and the car is so light it doesnt really need a 351 to scream. My brother had a 65 coupe and 66 Fastbackand the 65 got totaled and the 66 got a 302 buiult in it with 4 speed, very sweet but the block had been through a barn fire and we never knew it so after several clutches to try and eliminate a bad clutch shudder my brother traded it in on a 86 GT (he only got 2500 bucks in trade for it) .
      Good Luck
