      NHRA Convertible Roll Bar Requirements?
      Does anyone know at what et what equipment is required?
      Im hoping my 69 camaro vert w/ modded LS2/T56 with drag radials will run a low 12 or maybe a high eleven if I'm lucky. Thanks
      I did a search and it was old info, things might have changed.
      New Jersey
      13.99 or faster needs a roll bar. I think 4 point is ok to 11.50. You need a 4pt harness, and a snell 95 helmet, and reverse lockout.
      This should help: http://www.nhra.com/tech_specs/ETQuickRef.html
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
      Thanks for the info.
      Im not sure but I thought they recently lowered the conv. limit to 13.49
      Aug 2005
      Asheville, NC
      Quote Originally Posted by Marktat
      yep that is what the link says, "C/13:49" next to roll bar even though it is in the 13.99 column
      how do we find out the #of points & tube thickness, etc.. & is 4:11 the section in a rule book?
      Don't have rule book, but the 13.49 number stuck in my head from past research because I just finished a 6 point in my 67 RS Conv.
