    Thread: did i mess up
      mount joy pa
      did i mess up
      i put bleeder at 6 o clock not 12, will it be ok or do i have to pull the engine and tranny back out. or can i use something like a mityvac.never used a hydraulic clutch so i don`t know how they feel but this feels to soft. any help mike
      Delaware, OH
      You should be ok. My bleeder is at 12-o'clock but I had to bleed at the reservior to get all the air out. Jason's (malibujason79) advise at the following thread worked great for me.
      "crack open your your bleeder at the t/o bearing, once you get fluid you can close it. take the lid off your clutch reservoir, and slowly pump the clutch pedal. you will see tiny bubbles rising up if you still have air in the system."
      https://www.pro-touring.com/forum/sh...ad.php?t=23591
      mount joy pa
      dhardison, that worked good i think. the pedal has feel to it now. i did the slow pump with the clutch pepal.and no air bubbles, did the pump again but this time i started at the master cylinder where the rubber hose starts for the reservior and squeezed it and worked to the reservior, lots of air, did that 6 times and had to fill the reservior again. thanks. man i did not want to pull that engine again mike
