Thread: S60 rear
10-28-2006 #1
S60 rear
S60 axle is the same as dana 60 or what is it mounted on? Is it Special Strange housing?
Olav
10-30-2006 #2The S60 is Stranges answer to a stronger aftermarket rear for hard big cube, big torque, sticky tire usage. It is essentially a Dana 60 with welded axle tubes and available with a whole host of options. It can be ordered to bolt into GM A & G-body's with a four link rear suspension. It can also be ordered to fit GM's F-bodies. They have centers from the TracLok to a spool and drum brakes to a custom Baer set up. If you have the coinage you can order a virtually indestructible rear end to your door completely set up and ready to rock! I can't wait to put one in my Goat!
Josh --"GTO is for kicking up the kind of storm that others just talk up" Pontiac Ad 1964
10-30-2006 #3
