      baldwin park,california
      Need Info on My LS Build
      Ok, just want to make sure i understand what i need. i have a Lh6,5.3 with dod. i want to put a ls6 intake on it and a cam swap, i red that the heads on this engine are the ls6 type. casting on the heads are #799. so i need to change the acc, brackets im going to use f-body for that. also the intake and t/b but would i use everything fuel rail, injecters? for the cam swap would i use ls1 valve train or ls6? lifters, pushrods springs thanks for any input p.s im going to disable the dod
      Nov 2000
      O-town
      Check LS1.tech, killer site, tons to learn there,
      I think the 5.3 heads just have a smaller chamber to raise compression, LS6 heads have sodium exhaust valves, aftermarket pushrods for sure, Ithink you would use all the LS1 intake stuff for the Nova swap, hope I helped alittle, Steve
      Maryland
      I was talking to someone else about this,and was thinking,you could run the Edelbrock 4bbl type fuel inj. manifold and rails [$400},make an adapter for your throttle body{if its cable driven} and run all your stock truck acc. and brackets.And no 5.3 heads are not like ls6 heads.The 6.0 heads are the same except for chamber volume
      thaks for the help guys
      I would defintally switch to the LS6 intake over the stock LS1 more power thru-out the hole powerband and will handle upto 450hp, and if you could find a set of casting # 243's real cheap worth the money also.
      2004 Pontiac GTO
      Bogarts 15x4 front 15x8.75 rear
      BMR Suspension
      Yank 4400 Converter
      Stainless Works 3" Exhaust
      Fast 90/90
      CompCams Custom Grind 228/232 on a 110lsa
      CNC'ED Texas Speed Cylinder Heads
      Custom Tune by Hoosier Performance
      Best ET to date is: 11.33 at 118mph w/ 1.52 60'
      this was before the Fast Setup!
