    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 47 of 47
    Thread: Chevelle update
    1. #41
      livermore ca
      i love the stance i also have a 65 and was woundering how low it is in the front and rear and what size rim/tires u are running
      looks sweet!!
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
    2. #42
      The tires in fron are 245/40R18 now. but they are a little too wide for this stance, so i probably change them for some 225/40 tires.
      I will probably raise the front spoiler a little bit.
      By the way! like your 65 project!
    3. #43
      livermore ca
      Quote Originally Posted by Torbjorn
      whats on the back?? and how much did u lower the car
      65ss chevelle
      63ss nova
      3:73
    4. #44
      Those in the back are 265/35R18 on 10inch wide. Belive the offsett is 15 or 18 mm.
      If you like i could meassure the distance between car and ground
    5. #45
      livermore ca
      if u could that would be gr8!
      65ss chevelle
      63ss nova
      3:73
    6. #46
      meassures
      OK !
      Meassures taken from the floor and up to the Rockerpanel up front and in the back. It sits 10 mm lower in the front.
      I tested the stance by jacking up the rear a little bit, and it seems like it could bee a bit higher in the back
    7. #47
      Little report from the garage!
      Updated the electrical system since I had to add some compnentsto it.Mostly for the remote door opening system.
      Seems like the main unit were not powerful enought to supply the door solenoids, so I had to add two relays to do the job. Here a picture from the mounted solenoide and wire to the door latch.
      Had to test the riding position, an it feels quite good.
