    Results 1 to 13 of 13
    Thread: cut springs ?
      cut springs ?
      ok i no this is not the idea thing to do !? but for now i was thinking of cutting the front coil springs on my 67 camaro . my question is should i cut from the top or bottom ? what to look out for ? thanks
      Mesa, AZ
      its all good to cut them. I cut a coil and a half from mine then heated half way around the end from where I cut red hot and bent it flat so the spring will sit flat in the spring perch. I dont believe it matters which end you cut from. If this explanation isnt clear enough I can whip something up in paint to show what I mean.
      May 2002
      Northern California
      cut the top for drag racing and the bottom for other. half coil at a time please. how far do you want to drop?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mesa, AZ
      why is that? I have never heard this before
      ok thanks guys!! i would like to get it down 2 to 3 in ? so it doesnt matter i can cut the top or bottom ?
      Feb 2002
      Springfield, MO
      A coil and 3/4 without flattening the ear on my old stockers dropped it 3 1/2". It all depends how wore your springs are.
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      May 2002
      Northern California
      Quote Originally Posted by hotroddr
      Friends and I found this out many years ago. He screwed up and cut the wrong end (top) and found that his front end moved easily. I was told it may have something to do with the top coils being tighter (closer) to help store energy.
      Also heating the pigtail is not necassary. Heat can cause an unwanted change in metal hardness and an unpredictble height change.
      I have also found that with a new spring the height cut off can be multiplied by 2 to figure full weight drop on vehicle. ie: Say the free standing height of a spring is 14" from where the spring can sit flat. Cut 1" off of the height would drop the car by 2". This has been very accurate in my experience within 5/16".
      Feb 2006
      SoCal
      I agree with Mr. Quick.....I cut mine 1 coil and it dropped 2 1/4"!
      ***Under Construction***
      Build Update Link:
      Delaware, OH
      Quote Originally Posted by novanutcase
      Same here with my out of the box Hotchkis coils. I have a new pair on order and will only cut 1/2 coil this time.
      Anyone need a lightly used pair of Hotchkis coils???
      May 2002
      Northern California
      how far did you go? You can still use with a screw jack.
      Sep 2002
      San Jose, CA
      1/2 a coil = 1" of drop on 2nd gens... I think the 1st gen is the same coil ratio
      Just call me Brett
      Fontana, CA
      Quote Originally Posted by Lowend
      This has worked for me on 2 second gen and 3 first gen cars.
      Nick R.
      Feb 2006
      SoCal
      i'm with these guys. i dropped 1 7/8" with one coil off.
      1967 Camaro RS
      LS1, T56, LT'S, LS6 intake, ASP pulley,C6 Z06 clutch, Detroit True-Trac, 4:10 gears, GM 8.5 rear, strange 30spline, HOK Cinnamon Pearl Paint.
