      Houston, TX
      GW Springs and Competition Engineering Bars
      I have a 1969 Camaro with Global West rear leaf springs and I am trying to install Competition Engineering Slide-A-Link bars. There seems to be a problem with this combination.
      I pressed in the aluminum spacer on the front sping eye. A bracket from Competition Engineering is then supposed to go around the eye and be the anchor point for the front bar. It does not slide up far enough with out hitting the spring.
      Has anyone else had this problem? Does anyone have this combination? Does Cal-tec bars work with GW springs?
      Thanks in advance for any help.
      Phillip
      Phillip Lawrence
      1969 Camaro
      LS2 with a Kenne Bell
