Thread: Air Ride?
10-21-2006 #1
New to Pro-Touring
- Jan 2006
- 35
Air Ride?
I have a 67 camaro and I'm going to mini tub. Now my question is that the air ride Technologies rear suspension says that it bolts to the oem leaf mounts. With the minitub, will the Airbar suspension still work?
10-22-2006 #2It will work for sure with the DSE mini tubs. As long at the front leafspring mount and the inner portion of the frame rail is unmolested, the AirBar is a bolt-in. You may have to trim a sliver of metal off the cradle flange where the DSE tub meets the framerail. If you are actually removing or replacing the framerail, a weld-in 4 link would work better.
Here is a link to the installation instruction page. Scroll down to the page for the Camaro AirBar...there are some good images there in a PDF file.
http://www.ridetech.com/instructions/instructions.asp
