Results 1 to 20 of 22
Thread: Belt mounting to rollbar
- Nov 2005
- 38
My 6-point roll bar is installed and I知 ready to mount my bolt in 5-point belts. My question is how to mount the shoulder harnesses to the cross bar. I noticed that some use a single bolt in the crossbar to fasten both shoulder harnesses, while others use two bolts, one for each shoulder. I知 leaning towards the two bolts as the single bolt method may cause the belts to rub too much against my neck. Any feedback appreciated regarding safety, comfort and NHRA legality of two bolts versus one bolt option.
10-22-2006 #2Seat belts!
Weld 2 bungs through the bar about 6" apart exactly shoulder level, don't put them lower than your shoulder creating a pinch point! That's the way they are mounted in cup cars!
MarkAbility is not being able to do something once or twice.Ability is being able to perform upon demand!!
10-22-2006 #3actualy they should be below. not at shoulder level . thats what the nhra rule book says as well as the seat belt mfg. if they are mounted at shoulder level , and you go upside down they can.t keep you you from droping down . i would mount them 4'' below your shoulders .tabs or bungs thru the bar are fine. just make sure to mount them at an angle that will pull rather than bend your bolts or tabs. also unless they go thru your seat .mount them only 3or4'' apart. if you put them too wide apart they will slip off your shoulders too the sides. i'm not trying to contradict the other reply. but this is how it's done at my shop. you can't mess around when it comes to safety. i found theese diagrams online from a seatbelt mfg. hope it helps.
12-20-2006 #4That NHRA book is either old, or WRONG. The FIA, SCCA, and IMSA require that you ALWAYS mount shoulder harnesses at, or slightly below shoulder height, usually not more than 2", NEVER on the floor. Most safety equipment manufacturers installation directions want you to mount the shoulder harnesses up to 30 degrees ABOVE the shoulder and not more than 5 degrees below. Of course, the farther back you mount the harnesses, the lower or higher you can go and still retain the proper angles. The shoulder harness is NOT to keep you in the seat when inverted, the lapbelt is. The shoulder harness is to keep you from moving forward during deceleration. Mounting the shoulder belts below shoulder height can and will cause spine damage from compression upon impact.
Originally Posted by quadfather
Tommy
Tommy Souren
"The older I get, the faster I was."
Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
10-22-2006 #5
- Nov 2005
- 38
Good info. Thanks guys.
10-22-2006 #6
