    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 76
      Lafayette
      Let the winter projects begin
      Well my winter projects have started. A few of us pulled the bed tonight, so that I can clean and paint the frame. Hopefully after that is done, I can start on the motor and trans swap. On to the pics.
      Scott
      Built LTX, TKO600, 12Bolt
      Mar 2003
      Lafayette, In.
      hey ya bum !
      whatcha gonna do with the stock 4.3 and everything along with it?
      what kind of miles are on it?
      beer, my garage......worky worky !
      In process!
      1972 C10
      Roadster Shop Fast Track chassis
      LS376/525
      Lafayette
      Quote Originally Posted by TRILOGYZ28
      hey ya bum !
      its beer, my garage....work worky!
      Im not sure yet. It sure would make a good motor for that blazer and it only has 104k on the clock.
      Scott
      Mar 2003
      Lafayette, In.
      Quote Originally Posted by lower90xcab
      the one that is in the project blazer i am working on only has 90k on it, i was hoping to find one with 50k or less.
      might have ya pm me you address....i could possibly swing by sometime and check out the project some weekend when you are working on it.
      Lafayette
      thats cool....i would like to check out the blazers and the nova.
      Scott
      Lafayette
      Little update: I got most of the passenger side frame rail ready for paint. I just need to hit it with a wire-wheel to knock off the surface rust then its ready for paint.
      Scott
      Mar 2003
      Lafayette, In.
      what kind of paint you gonna use on it ?
      Lafayette
      im going to use paint code 7777 rust-oleum black.
      Scott
      Nov 2000
      O-town
      Basic assembly!
      ready for brake lines, rotors hydra boost, calipers etcetc,
      Lafayette
      Another little update: Got the rear suspenion pulled tonight. Hopefully tomorrow I can get the gas tank pulled, so that I starting using a grinder with a wire-wheel on it. Im tried of scraping all that by hand.
      Scott
      Lafayette
      Its been for ever since I updated this thread. So since the last update, the frame was painted with Por-15 (awesome stuff) and put back together. The bed had a roll-on bedliner put on it top and bottom. The truck is now turned around up on jackstands, so that I can start working on the rest of the frame. On to the pics.
      That third shock was taken off and cleaned and painted.
      Looks blue b/c it was still drying.
      Leather seats and 5spd console from a blazer.
      Envoy headlights with HIDs coming soon.
      Hopefully the motor and trans will be here in the next month or so.
      Scott
      Lafayette
      Well its been awhile since I have updated this thread. Not much has changed on the truck since the last update. The framerails under the cab are stripped and ready for Por-15. I have been working hard on the motor (LT1) the last month. I got a box of goodies last night. Included in the box were; Comp cams 306cam, 918beehive springs, 1.6 pro mag rr, retainers, keepers, Cloyes Lt4 roller timing chain and GM Performance Guideplates for Aluminum Bow Tie Heads. The heads have been cleaned up and ported matched to the intake along with new valve seats put in. I should be picking the motor up from my dads this week, so that it can start going together. Next on the list of things to do is buying the trans.
      Hopefully I will have pics of the motor on the engine stand really soon.
      What do you guys think about these valve cover along with painting the engine orange and leaving the heads, intake, and timing cover bare alum?
      Canton Fabbed Alum Valve Covers
      Scott
      Lafayette
      Well the motor is just about finished up. I just need to finish the plug wires and a couple of other odds/ends.....Here are some pics..The headers and exhaust are going to be sent out for coating...The front end is coming apart this weekend so that the frame can be cleaned and painted...Here are the pics.....
      Scott
      Mar 2003
      Lafayette, In.
      get with it.....lol !
      btw, nice seats......
      In process!
      1972 C10
      LS376/525
      Apr 2007
      Sorry in advance if it's bad taste to bump old threads here, but I couldn't help it.
      That's a badass truck. I was just wondering what suspension mods you have as that truck sits absolutely perfect. Also, how much better is the handling from the factory ZQ8 set up? Not looking for a scientific answer, so anything from "a little better" to "hell on rails" would suffice.
      livermore ca
      how do u like those valve covers? iam planing on ordering some for my car.
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Lafayette
      I believe that it handles a lot better than the factory zq8 set up ever did....The body roll is almost completly gone. The truck is dropped 5/6 using all belltech parts; 3inch coils, 2inch spindles, 3inch leafs and 3inch blocks..I really should have notched the frame 2.5inches in the rear to help get some more travel in the rearend, but it really doesnt bottom out at all..Right now im looking at the getting some global west tubular control arms and coilovers for the front...I would like to also four link the rear or put it in a trailing arm setup with coilovers too.
      As for the valve covers...im really happy with them..im going to have to do a little grinding on the right one to clear my rocker arms...other than that they seem to be a great product.
      Scott
      Lafayette
      xmas in july....
      i got a little present today....so i thought i would share...
      its a tko 600 with .64 od....
      Scott
      Chicago
      yahoo - subscribed
      marty-mj
      Feb 2007
      very nice job, love how clean it is keep up the good work
