    Page 28 of 30 FirstFirst ... 18 23 24 25 26 27 28 29 30 LastLast
    Results 541 to 560 of 585
    1. #541
      Sep 2007
      Litchfield NH
      My 1981 Malibu
      My current project. 1981 Malibu. Currently powered by a 454 with a TH350 trans, swapping it out for a 5.3 and 4l60e within a year or two as well as some new wheels and suspension. Name:  Malibublack2.jpg
    2. #542
      Jan 2014
      virginia beach,VA
      1979 Malibu ..
    3. #543
      Aug 2010
      Bumping this back to the top!
      83 cutlass t-top (insanely clean) hoping to ls swap this one
      86 cutlass to swap some parts from (mainly interior)
    4. #544
      Jan 2017
      San Diego, CA
      Soon to be owner of 1984 Buick Grand National - 3.8L SMPFI Turbocharged V6 - Factory Astroroof, Lear-Siegler Leather Seats, Power Windows and Door Locks
Size:  20.7 KB Name:  20161227_121127.jpg
Size:  12.7 KB Name:  20161227_121239.jpg
Size:  20.5 KB Name:  20161227_120401.jpg
Size:  20.7 KB Name:  82311-01M__43632.1483018250.1280.1280.jpg
      Planning a frame-on pro-tour restomod - ridetech Level 2 Adjustable Coilovers - Willwood Big Brake Kit - Hotwire and Walbro fuel pump - 42# Injectors - '87 ECM with Turbotweak Emission and Power Chips - Modern 2DIN GPS Navi Stereo with SiriusXM, New Vintage gauge package
      No intentions to dragrace but would enjoy a good trackday or autocross, will be a driver not a show car.
      Target is to look somewhat like this
      JK
    5. #545
      Feb 2017
      Did you see the build thread for that GN? Crazy... custom frame work, 6 speed 4L80e... incredible car.
    6. #546
      Sep 2016
      Quote Originally Posted by mc84_zz4 View Post
      ^^ X2 on the well said.
      Some aftermarket parts I would like to see are:
      - aluminum cowl hood(s) 2", 4"
      - deep front inner fender tubs for big tires
      - rack & pinion kit
      - trunk/seat reinforcement bars
      - replacement dash cluster pod, that can fit some gauges AND keep the A/C
      - rear frame bolt-in crossmembers
      - interior door panels / rear seat panels
      - billet hood / trunk hinges
      - electric window motor/harness upgrade kits
      6 YEARS LATER AND WE STILL DON'T HAVE MOST OF THIS STUFF.
      At the very least, G-Bodies should have some aftermarket "design" for hood/decklid hinges. Rack and pinion would be huge. TMI Interiors should add G-Bodies to their line as well.
      I think plenty of people have G-Bodies, but I'm not sure how many that do own them, want to put the parts into them...with the associated cost to do it.
    7. #547
      Feb 2017
      Plainfield
      86 Buick Regal and 86 Cutlass Supreme
    8. #548
      Oct 2016
      Kansas
      Well, mine is completely scattered at the moment with the entire suspension and brake swap. Here is when I was just getting started.
      On the parts front, I am thrilled to even have what we have. The reason I haven't done anything to date is quality adjustable control arms and certainly "better" anti-sway designs compared to even the factory F41, add on bracing, steering components, and much better brakes have only become available at all in recent years. Now, I won't be turning my G-body into a C5 or 6 but even thinking that is nuts. I am purely looking for the . . . holy crap, that's an Oldsmobile out there? And, just the fun of doing it all before going to the great salvage yard in the sky . . .
    9. #549
      San Antonio, TX
      Quote Originally Posted by focused313 View Post
      Wow, that's a flashback to 2011...
      From the original post:
      A few updates or alternatives to this partial list:
      Several panels available for gauges fitting into dash cluster
      Also Dakota Digital has new panels with the latest features as a drop-in replacement
      Still no aluminum hood, I bought a 70+ pound Goodmark 2" cowl hood to replace the stock 70+ pound stock hood.
      - rack & pinion kit
      still no known Rack & Pinion bolt-in solution, although several full frame replacements are available, and have it: Schwartz, Roadster Shop
      A definite upgrade from the stock close-ratio units:
      Performance re-valved/benchmarked Delco 670 steering box from Lee Performance, as Lee is back in business (may have delays due to finding decent cores)
      Performance re-valved/benchmarked Saginaw 800 series boxes, also from Lee Performance http://scandc.com/new/node/848
      Make your own still is available... I used some 2" flat steel, one X in each seat 5 bolts per side, also one horizontal bar across the rear deck bolted in.
      http://www.motortopia.com/files/cars...Thumbnail1.jpg
      1- UMI Performance has a rear shock tower brace:
      http://umiperformance.com/catalog/in...ex&cPath=8_404
      2- U-Haul class2 hitch works great to tie together the loose frame ends, and add some needed structure. It evens works with the stock SS exhaust hangers, just need to swap L/R hanger brackets and reverse clamps.
      Part number: 36104
      www.uhaul.com
      Not-as-sexy pic: http://www.motortopia.com/files/1246...08d7/image.jpg
      GNS makes brackets that bolt to the rear bumper mounts, make your own cross-bar to size..
      http://www.gnsperformance.com/bodyframe-g-body
      Additional frame bracing / mods:
      - Front end frame braces:
      You can find front-end frame braces from:
      www.scandc.com
      www.umiperformance.com
      www.speedtechperformance.com
      - Hellwig G body frame bracing
      Available thru SC&C http://scandc.com/new/node/977
      Full picture: http://scandc.com/new/system/files/i...20G%20body.jpg
      Frame-Notch Kits (in no particular order):
      - Gbodyparts Frame notch kit
      http://www.gbodyparts.com/product_in...oducts_id=1560
      - UMI also offers a Frame Notch kit:
      http://umiperformance.com/catalog/in...oducts_id=1068
      Dave
    10. #550
      May 2010
      Houston, TX
      I've seen this kit:
      http://www.unisteer.com/new-products...inion-kit.html
      But I don't know of anyone that has it.
    11. #551
      May 2017
      1987 Monte Carlo SS AeroCoupe
      Hello PT Friends,
      Quick intro:
      I have a 1987 Monte Carlo SS that I bought when I was 16yrs old back in 1993.
      Recently, I removed the H.O. 305 and replaced with a BPE 383, Built 700R4, and my most recent addition is a Full ridetech Upper/Lower StrongArms, Front and Rear MuscleBar SwayBars, and of course Adjustable Coil Overs.
      Today the AeroCoupe is on the alignment rack getting dialed in....
    12. #552
      Jul 2017
      LS swap
      1979 cutlass in the house, I will be looking for info on a LS swap....
    13. #553
      Louisville, KY
      G-Body owners are hilariously cheap as a group. And the platform is limited. There is only so far you can take it with bolt-on parts. You can easily make it wonderful on the street, but running at the pointy end with modern equipment can't be done without fabrication, and that's beyond the skill and resource limits of your typical G-Body owner right now.
      Andrew Scott
      '87 GN - 12.8 @ 108
      https://www.andrewdscott.com
      Instagram: @andrewdscott12
      Twitter: @Andrew1427
    14. #554
      Quote Originally Posted by Turbo6inKY View Post
      You most certainly are being POLITE in your description of your fellow G Body Owners!
      The ONLY cheaper bunch that I know of are Foxbody Mustang owners. It takes 4 of em to raise $1,000 to buy an $800 car!
      Mike
      www.musclecardeals.com
    15. #555
      See my signature!
      88 Monte SS
      80 Malibu
      GM G-bodies: Because I can't afford a 69 Camaro
    16. #556
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by vintageracer View Post
      I don't know,Mike, the G-body El Camino guys are as cheap as they come. lol
    17. #557
      Here's BMR's Monte SS
      we just came out with a rear Coilover Conversion Kit
    18. #558
      Dec 2011
      Pensacola, Florida
      A few pics of my junk:
      Untitled by malibu_lvr, on Flickr
      bu3 by malibu_lvr, on Flickr
      bu4 by malibu_lvr, on Flickr
      bu6 by malibu_lvr, on Flickr
    19. #559
      Jul 2013
      St. George, UT
      I see a lot of G-body guys being chea...er...thrifty and cost conscious for whatever reason, some of us just have to. Sometimes I wish though as a group we'd pull our heads out. There's no such thing as cheap performance unless generally you replace the word cheap with garbage. No matter what we build there's some cost involved and many of our G family just needs to accept that. That doesn't mean you have to either build a $60K+ car or go home, you just have to spend a little time to know where to put the money to get the results you want. Much better than jumping on FB and the first question you ask is "where can I get cheap suspension for a pro touring build?"
      Because my wallet dictates it sometimes I'm pretty cheap...uh...thrifty too, but for prolly less than 15K I have over 500 n/a SBC horsepower, an incredible suspension which is all bolt-in (besides a small bracket welded in to swap to coilovers up front), brakes that stop the car well and a gnarly wide stance. Most importantly it's an absolute blast to drive and so much fun to play with the import boys at SCCA events. It's got a cool name too, but that was free. ;)
    20. #560
      Jul 2013
      St. George, UT
      Hey Malibulvr- who'd you get your front air dam from and is there any chance you could measure your ground clearance below it and below the frame rail just behind the front wheel for me? Thanks!!
