    Results 1 to 20 of 31
      Rolla, MO
      BMW wheels on a 2nd gen
      I got my wheels and tires installed and thought I would share some pics.
      I made a custom center cap and it works great. I started with a cap from Armour All tire foam. It is the right diameter and has a tensioning rib on the inside. I cut it down to the right height and the Rondell center cap snapped right in. I covered the exterior of the plastic cap with brushed aluminum shelf paper of all things. It is actually an aluminum foil so it should wear reasonably since the car is garage kept. Everything snaps right in and is tight enough that it is not going to come off by driving, although I may put a little bead of silicone on the inside of the cap to make sure.
