      Phoenix,AZ
      Posi Rear or not
      Is there a way to see if a car have a posi rear or not? One time I had the car on jack standsto check to see if the rear wheels are warp or not. Put it in reversee and left rear tire spin and the right rear stand still. Put it in drive and both wheels spin. I think do have a posi in the rear from factory.
      James W.
      1987 Oldsmobile
      Dublin, CA
      You should be able to tell from the differential code stamped on the axle tube or housing. Once you have that, just do a web search for the codes for your year of car.
      Brent
      TuoCo, CA
      Jack the car up to get the rear wheels off the ground. Put the tranny in neutral, engine off.
      Turn one rear wheel by hand. If the other wheel turns the same direction, posi. If the other wheel turns the opposite direction, open.
      Steve
      Check it Out Here
      Cumberland, Maryland
      Change the diff fluid is the easiest way to find out for sure :-P
      Miamisburg, Oh
      I do what eville does.
      Phoenix,AZ
      Thanks for asking my qusetion guys.
      James W.
      1987 Oldsmobile
      Apr 2004
      OKC, OK
      The only sure fire way is to open up the rear and verify if there is a clutch and spring pack in the dif.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Mike is right, this is the only way to be sure. A posi with worn out clutches will act just like a standard differential and a damaged standard differential can act like a posi with the wheels off of the ground.
