Thread: Heidts New 4-link kit
10-06-2006 #1
I was just reading a few magazines last weekend when I found an article talking about Heidts new 4-link kit made for 1st gens.
http://www.heidts.com/heip29.htm
The kit is a bolt on deal and comes with everything you need except the rear end (and you can order it with one if you want to)
What got me is the price, $995 with coil overs!
Unless I have missed somethiing this is the most affordable way to get a 4-link that is designed for the 1st gen.
Now i know that there are alot of good 3 & 4 link kits out there currently but the cost is just too much for me at this point and time.
My question is... is there something fundamentaly wrong with this kit that I am just not seeing?
Ideally should the top bars be a little longer? (i cant remember the rules that go along with a good 4 link)
The only thing I would probably do is go ahead and weld in the brackets rather then just bolting them in.
Thanks for any input
1967 Camaro - Done!
1968 Camaro - Underway
10-06-2006 #2I'm going to ask you this: Why not put $995 into your leaf setup? You'll be way ahead performance-wise, and it will be far easier. Leafs can be made to work pretty darn well. It sounds to me you want a 4-link just because it's not leafs.
Also keep in mind: most to all bolt in rear suspensions for Camaros will sacrifice some (or alot) of performance in order to get the package to fit. I don't know anything about that kit, nor will I comment, but don't let the price tag draw you in.Matt Jones
Mechanical Engineer
Art Morrison Enterprises
10-13-2006 #3Rear suspension
In your response you arent shying away from the leaf spring configuration. Although I can see the "corner cutting" of the Heidts bolt in system, I would like to know if you would give me your take on the Art Morrison triangulated 4 link system for 1st gen camaros. I would think technoledgy has advanced since the leaf spring. Thanks for your knowledge.
10-13-2006 #4
