Results 41 to 60 of 97
10-11-2006 #41
Starting The Transformation
- Jun 2005
- 379
I think that the results of the struct foam addition will be mixed at best. Yes, it will make the "A" pillar itself more robust, but it will do nothing for the attachment points (where the pillar meets the cowl and roof). I believe that there is much more deflection at the joints than in the pillar itself. I think that the struct foam is more benificial when used on items that are under a twisting or bending moment than under compresion or tension.
Originally Posted by hotroddr
Do you mean like a torque tube in a 3 link rear? I guess it would work if you came off the top of the firewall and followed along the trans tunnel and tied it off with a cross brace at the rear torque boxes.I have also been toying with building a similar style of brace as your front shock tower brace except as a backbone on the center console. What I mean is leave the original sheetmetal there, and weld a tubular structure onto it to form a backbone from the firewall area to the backseat area. Have you considered this? I believe this will cut down on torsional deflection without intruding into the passenger compartment like a cage would. I would be interested to see how this would work.
But, I believe, in general, that it is better to beef up the perimiter than it is to reinforce the center.
Thanks for the kind words. I am taking a lot of what I see on late modle cars and applying it to the early stang chassis. Rockers on late modle cars are very stout.I like the idea of the beefed up rocker panels for various reasons, the first being crash safety. A subframe connector does nothing to help you in the case of a side impact, but a beefed up rocker panel could very well minimize intrusion. It also as you have stated, ties into the structure of the body which is nice. It might be beneficial to beef the rockers up AND install subframe connectors in a car like a camaro or firebird where there is a subframe that bolts to the middle of a flat panel. Keep thinking outside the box!
Also, I have to think outside the box. I tried to get inside the box on several occasions, but no one will let me in. :-)
Bob
http://sn65.com/
10-11-2006 #42
- Jun 2005
- 379
Hi Mark,
Originally Posted by astroracer
I guess this thread has gottena bit off base a bit. Originally I was trying to get a few thoughts on how people thought that SFC's functioned. A lot of people I talked to thought that it was a "torsional" device. While I believed that there were some minor torsional gains, I figured that the real benifit of a SFC was in lengthening the lever arm.
Now we are talking about uni-body chassis design.
Maybe we should rename the thread to match the scope of the thread?Bob
http://sn65.com/
10-11-2006 #43
- Jul 2006
- Chesapeake, VA
- 679
IMO the key to success with your approach is looking for the "hinge points" in the chassis. By that I mean that beefing up the rockers will have minimal effect if the subframes aren't tied in with sturdy torque boxes. Similarly, bracing the shock towers into the firewall better won't be fully effective without providing a way to take those forces straight into the rockers because the firewall will just flex at the bottom like a hinge. Obviously you've put a lot of thought into how forces move through the chassis and you are reinforcing those force paths. No matter how they're constructed it's hard for me to imagine subframe connectors being as effective, especially in torsional loading.
10-11-2006 #44
