Results 1 to 9 of 9
09-30-2006 #1
- Dec 2005
- Germany
- 36
Problems with 92' LT 1 Corvette engine
Hello!
Perhaps there are some enthusiasts which have the same engine=>
I installed a 92'Corvette engine in my 69' Camaro.
Now I have the problem that the engine won't run so smooth like before.
A few weeks ago it fast the first time that the engine had some misfire and a bad throttle response. If it will be a carburated engine my tipp is that there is not enough fuel, not a ignition problem.
Then the problem gone. Why ? This day it was the same again. During driving the described problems started again. It's possible to drive home with 2000 rpm, but not depress the pedal to fast => than the engine will go down in rpm.(It's like too much air for too less fuel)
There's no failure on the engine check light.
I reroute the fuel lines last winter and the line between tank and pump is now four times longer or could there be a leak?
But why the engine runs normal all the time this summer?
Or could this be the not trouble free ignition system? (The engine has 40000 miles)
HELP!Night Rider => My car
69'Camaro
92'Corvette LT1 engine, 4L60, shorty headers, Flowmaster, Eibach, Vette wheels=> soon coming:hotchkis leaf springs nova rear w limited slip, Corvette brakes
09-30-2006 #2Sounds like a fuel issue. When high pressure fuel pumps go bad, they sometimes act this way intermittently. You need to get a fuel pressure gauge and tape it to the window and go for a test drive. I believe the pressure sould be around 45 PSI at idle and should go up 3-5 PSI when you give it gas.
If fuel pressure is ok, next would be ignition. It could be the coil or the optispark on its way out.
09-30-2006 #3
