Thread: Pinion Offset
11-10-2004 #1
Pinion Offset
As far as I can tell GM rear axles (10 bolt and 12 bolt) have the pinion offset 1/2" towards the passenger size of the vehicle. And on Ford 9-inch axles the pinion is offset 2" to the passengers side.
Aside from driveshaft tunnel clearance issues is thier any problem with having the pinion offset the extra 1 1/2"? If you buy a 9-inch housing that is custom built for a GM car is the housing built with the 1/2" or 2" offset?
I am wondering if the extra offset will adversly affect the U-joints in any way?
Thanks.R.J.
