      Feb 2006
      Anderson, SC
      LSX in a G-Body - Accessory Mounting?
      I am considering replacing the 454 in my '84 Monte with a carbureted LSX engine.
      The car currently has a March serpentine conversion kit for the water pump, power steering pump, and the alternator. What are the simplest options for mounting the accessories on the LSX engine?
      I may reinstate factory-style A/C at some point in the future, but for now I need a clean and simple way to mount my existing accessories.
      Thanks for any help,
      Rick
      2010 Camaro RS/SS
      2009 Challenger SRT8
      1986 Monte Carlo SS
      http://metcomotorsports.com/proddeta...?prod=1986MCSS
      1984 Monte Carlo SS
      http://metcomotorsports.com/proddeta...?prod=1984MCSS
      Sagamore Hills, OH
      You will probably have some of the same issues as an A-body. If you use the factory F-body brackets you could have clearance issues with the alternator and steering gear. Getting a Y-body set of brackets would cure that but you still may have some clearance issues with the a/c compressor and crossmember. If you want something fancy without clearance issues there is March and Street and Performance. Both avail in polished but a little more pricey. Then you can get into a Billet Specialties or Synister products set up and you are talking $2400. Depends on what you want to spend. Here is some links for ya:
      http://www.synisterproducts.com/
      http://www.montecarloss.com/ls1montecarloss/
