Thread: Front end is WAY too high!
09-25-2006 #1
- Feb 2006
- Columbus, GA
- 132
Help, anyone? I set my second gen Camaro on the ground and it's sitting 2-3 inches too high. Everything is new. Upper CA's are Hidts, Lower CA's are GW, springs are Hotchkis (small block). The engine is in (ZZ502, Aluminum heads) all accessories are mounted. I originally had the Hotchkis BB springs but swapped them out for the SB...it's still too high! Any suggestions?
__________________
1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
09-25-2006 #2Did you tighten all the suspension components with the car on jack stands? If you did, the front end/rear end is in a bind. Loosen all the bushing bolts and other suspension components and re-tighten with the car resting on all 4 tires on the ground.
This allow the car to lower properly with no suspension bind. The car will continue to drop a little as you drive the car. Not much, maybe 1/4inch. You may still have to cut your front springs to achieve the desired height in the front end. I have had to cut every set of Hotckiss springs I have used to get the ride height I desired.
09-25-2006 #3
- Feb 2006
- Columbus, GA
- 132
Mike, Thanks for the reply...I don't think there's and "preload" on the bushings. I know the lowers are ok...they're del-a-lum (sp) and moved freely when I was replacing the springs. I'll losen the tops tonight just to be sure, though. Man, I'm going to hate to have to cut springs that I bought to lower the car in the first place
Tom1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
09-25-2006 #4LOL. I have yet to install mine, but I dont think I have ever heard of someone on this site NOT having to cut them. That would make for an interesting poll.
Originally Posted by tomspo04
09-25-2006 #5
