    Results 1 to 11 of 11
    Thread: Tire Question
      Tire Question
      Ok have my Wheels and I am going to buy tires in a week or so just a couple of questions
      I was going to use this setup
      Front Tire Size: 235/40 18
      Rear Tire Size: 295/45 18
      The only problem I have is I can't find Drag radials in a 295/45 18. So what would it look like if I ran a 295/35 18 in stead of the 45?
      Would this setup look ok?
      Front Tire Size: 235/40 18 BF Goodrich g-Force T/A KDW NT
      Rear Tire Size: 295/35 18 BF Goodrich g-Force T/A Drag Radial
      Thanks for all the help
      Lafayette
      Quote Originally Posted by Scarface
      Sorry for whoring your thread with bad posts, but I hit the wrong key three times. Anyways to answer your question. Here are the numbers for those size tires. I believe that they will look good with either rear tire choice.
      235/40/18
      Width 9.25
      Sidewall 4.16
      Diameter 26.33
      Circumference 82.74
      295/35/18
      Width 11.61
      Sidewall 4.06
      Diameter 26.13
      Circumference 82.12
      295/45/18
      Width 11.61
      Sidewall 5.23
      Diameter 28.45
      Circumference 89.42
      Scott
      Built LTX, TKO600, 12Bolt
      Thanks for the info and I am not sure how to delete the extra posts. Tried to delete them but couldn't figure it out
      Lafayette
      A mod will have to delete them. Im really sorry about those extra post.
      Scott
      Ttt
      No problem
      Thanks again for the info
      Jun 2002
      Long Island, NY
      I deleted the posts. I think a 295/35/18 will look great on the back of your car. That is the size I run on my 4th gen.
      Quote Originally Posted by Ralph LoGrasso
      I just wanted to makesure that it would look good with he front 235/40 18.
      I am going to try and order them late next week but I propably will not get around to putting them on until I get my car back from the painter. I will post pics when I get it back
      Thanks agin for all the info
      Jun 2002
      Long Island, NY
      A 235/40/18 is a relatively short tire at 25.4" (3.7" of sidewall). A 295/35/18 with an overall diamter of 26.1" will be a much better match as opposed to the 295/45 (which is 28.4" tall), IMO. The 295/45 would give you more of a modern pro-street look with the much taller sidewalls in the back, as opposed to a more balanced pro-touring look the 35s will give ya.
      Aug 2006
      Hampton Roads, VA
      I have 285/35/18's on the rear of my car and 245/35/18's front, sorry no pics for now, but it looks perfect and very balanced. With that fat of a rear tire you will still have a nice 4" sidewall in the rear, don't worry about looks, it will look perfect.
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Quote Originally Posted by Bandit
      That is good to hear so looks like I will be ordering them in a couple of weeks. If you have time get a pic of your car and post it I would like to see it
      Mchenry, IL
      the should look fine
      HE WHO DIES WITH THE MOST TOYS WINS!!!
      2012 Camaro ZL1 M6
      1978 Camaro Z-28 C5 Corvette Hybrid
      1999 Jeep Wrangler
      2004 Acura TL
      2002 Chevy Silverado
