Results 1 to 16 of 16
Mythbuster needed Big CID= less duration sensitive
Need MythBuster.. Big CID = less Duration sensitive.
Trying to pick a cam today and was made a little confused by the salesman so Im holding off.
I told him all my specs for my 406. Told him the RPM range Id like to make my power in. He quoted me a cam with 236* 242* at .050. I Questioned the duration being a bit high for the rpm range I wanted to stay in and he told me larger CID engines arent as sensitive to duration and the higher duration would be a better choice..
Does this sound right.
Motor is
406 CID
TFS 23* unported heads
.030 over bore
5.56 rods
trw forged pistons (they claim 10.5;1 with 64 cc heads)
Car has 3;55 gears with 2800 stall converter
will be running Doug thorley tri-Y and X pipe with mufflers to be determined later.
Id like the motor to make its power under 5500rpm With lots of low-mid range TQ
He suggested
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Retro-Fit Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,000 RPM
Intake Duration at 050 inch Lift: 236
Exhaust Duration at 050 inch Lift: 242
Duration at 050 inch Lift: 236 int./242 exh.
Advertised Intake Duration: 288
Advertised Exhaust Duration: 294
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.540 exh. lift
Lobe Separation (degrees): 110
Computer Controlled Compatible: No
Grind Number: CS XR288HR-10
I was thinking
COMP Cams
Basic Operating RPM Range: 2,200-5,800 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 288
Advertised Duration: 282 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.520 exh. lift
Grind Number: CS XR282HR-10Nothing says "I built this" better than tool marks and dykem blue..
