    Results 1 to 20 of 23
      Jun 2005
      T-56 Technical Data
      I went to my old work (a Chevy dealership) and asked the guys to print me out some data on the T56. I thought i'd pass on the information, since a lot of guys seem to have the same question i did!
      I have not yet put the T-56 in, but i figured if i had the same questions, i could certainly save a bunch of people the hassle of finding this out on their own.
      Jun 2002
      Long Island, NY
      Good stuff, thanks. Thread stuck.
      Rolla, MO.
      just FYI the speedo connector part number has changed, its #88987993 now
      and when you get the new connectors from GM the wires are not color coded, all wire is white
      but here are the pin outs
      Speedo connector #88987993
      pin A = Ground
      pin B = Signal
      Reverse Lock Out #12101857
      pin A = 12v Trigger
      pin B = Ground
      Backup Lamps #12085485
      pin A = 12v Trigger
      pin B = Ground
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      Huntington Beach, CA
      How do you wire up the reverse lock out in an aftermarket situation? For example a 68 Camaro.
      Rolla, MO.
      I plan to wire mine in with the brake light switch i.e. foot on brake equals reverse lock out disenguaged
      Matt
      T56 lock out
      is there a way t owire it to the nutral saftey switch? not too good with wiring
      May 2000
      Quote Originally Posted by RatMalibu
      pin A = Ground
      pin B = Signal
      pin A = 12v Trigger
      pin B = Ground
      pin A = 12v Trigger
      pin B = Ground
      GM Parts Directs shows this for the Speedo Connector:
      GM PART # 88987993
      CATEGORY: Brake Master Cylinder Reservior Hardware
      Aug 2006
      shreveport,la
      Can Anybody Tell Me If You Can Take A 6 Speed Out From A Lt1 And Change The Bell Housing And The In Put Shaft And Put It Behind Als1
      Dec 2002
      Lost Wages, Nevada
      It would be cheaper to purchase an LS1 trans... than to try and install the LT1 behind and LS.
      Walla Walla, WA
      Quote Originally Posted by jbirdcamaro
      If it's a 2.66 first gear LT1 T56, yes you can swap input shafts; and all of the LT1, LS1 and Viper T56s have the same transmission to bellhousing bolt patterns, so the bellhousings can be swapped too.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Elk Grove, CA
      T56
      I know I need to change the flywheel to install into my 69 Camaro, but which one will work? The stock flywheel is an 11", but does it require a different flywheel? Thanks for the wiring information.
      Mobile, Al
      Elwaupo... I'll be using a factory 10.5" which is also pretty light at around 17 lbs.
      Walla Walla, WA
      Here's a thread i started on Camaros.net that's got some useful information: http://www.camaros.net/forums/showthread.php?t=98387
      some where's in Ohio
      Complete T-56 Service Manual
      The T-56
      T-56_Service_Manual.pdf
      If there is a better way to get this up for everyone to access, let me know how and Ill do it.
      Rustburg, Virginia
      Quote Originally Posted by edl406
      The T-56
      Thank you for the service manual;)
      You will also have to swap out the trans to bellhousing adapter, along with the hydraulic master / slave assembly.
      John
      Jun 2010
      Thanks, Mine is not shifting into gear well and when hot in competition mode (read lauching it) the clutch pedal sucks down to the floor w more rpms.
      Jul 2010
      Monticello, MN
      Original data links appear to be dead. Any chance that they could be revived?
      Jun 2005
      I have them at my house robert ;) :D
      Feb 2014
      I have a t-56 out of my cts-v that needs a rebuild. how easy would it be to mount it up in a 68 firebird. it will be mated to a lq9. with I have to modify the tunnel to get it to fit? I can have it rebuilt and change the output housing to put the shifter where I want it. thanks in advance for any info..
      Pete
