      Aug 2005
      Cam Rec.- Blown and Injected BBC
      Hello. I need some help with a cam for my Chevelle. I built this long block last winter, and have since gathered a used Vortech V1 and Holley projection setup. Im glad I didnt buy a cam earlier.....
      69 396 2 bolt +.030
      3.76" cast crank
      6.135" Scat I beam bushed rods
      Speed Pro L2287-30F floating forged pistons
      781's, small valves, rough edges cleaned
      rotator elim, 4 angle vj 119cc
      Holley street dom dual plane intake
      Holley 900cfm 4Di Projection
      MSD ready-to run- may be replaced with HEI to computer control timing
      Harland Sharp roller rockers
      New Comp valve springs - 125#@ 1.8/ 315# open
      1 3/4" X 3" ceramic flowtech headers
      3" exhaust with Flo Pro mufflers, dumped at axle, but
      will probally have tailpipes put back on it
      68 Chevelle,
      Viper t56
      3.90 12 bolt
      car has power brakes and will soon have a/c
      I would like to run a roller cam, as I have wiped out 3 flat- tappets with this engine, the last one leading to this complete rebuild. I'm thinking hyd roller.
      I would like some advice on what cam specs to run with and without the supercharger. It is an older model straight blade impeller, and I'm not sure yet if I will be running it. For a useable powerband of 1500-6000, in a 3800lb car that will cruise at 2000 on the highway, what would you run?
      If I were to order right now it would be a 224/[email protected] .527/.544 with a 110*cl and 82* overlap. What do you think?
      68 Chevelle SS396. Pro-touring in Progress
      Pro-jected 396, TKO 600, 3.90'd 12 bolt, LS1 brakes.
      Sep 2002
      San Jose, CA
      You are going to want more Duration @050 with a wider lobe seperation.
      I would be looking at something like the Crower 245HR253 ground with a 114 deg lobe seperation. It only costs an extra $25 for a custom grind vs off the shelf and that will scream in a blown 396
      Just call me Brett
      Aug 2005
      Holy lift Batman. I dont think my springs will support that. It seems like they bound at .610"
      Sep 2002
      San Jose, CA
      Less than .610 lift... what are you a facist :D
      Its not a secret that I'm not a big fan of CompCams; but in this case the Comp NX298HR is going to be perfect specs for you.
      242/254@050
      .566/.575 lift
      113 Lobe Seperation
      Comp PN 11-414-8
      Just call me Brett
      Aug 2005
      That looks good to me too. Thanks.
