    Results 1 to 20 of 50
      Aug 2006
      Hampton Roads, VA
      BBC-Aluminum heads?
      Hey all,
      I am trying to justify the 2 grand + it would cost me to have a set of new aluminum Edelbrock or equivalent heads on my 402 Chevy Big Block. I am trying to guesstimate what kind of power and torque increases I would gain.
      Sorry I don't have all the specs with me right now, but I'm currently running the following:
      Block bored .010 over for 408 ci
      Domed Wiseco 9:6:1 pistons
      Stock oval port heads 2.19" Int 2.25" exh
      stock stamped rockers
      Comp hydraulic roller cam <.600 int/exh
      Crane hyd. roller lifters
      Edelbrock Performer intake
      Holley 750 vaccuum secondaries
      Hooker 1 5/8" primaries...2 1/2" dual exh w/H-pipe
      Etc...basically your typical mild street build with the huffing advantage of the roller cam.
      Never been on a dyno, but we estimate 400-430 flywheel hp/450 lb. torque.
      I would like to squeeze out closer to 500 hp from her, how close can I get with just the heads?
      Also, I want to keep the stock exhaust port locations for ease of header fitment. So no radical Brodix monsters for me.
      I will likely combine the heads with an Edelbrock Performer RPM intake.
      So:
      1. How much power/torque can I expect to gain?
      2. How much weight will I drop off the nose of the car?
      3. Can I drop compression ratio a point or 2 (to support future procharger install) and still see a decent gain?
      4. If you have any suggestions for runner size/chamber or head shape, I'm all ears!
      5. This is a "tall-deck" block from a truck originally, will this mess me up?
      Of course I know any estimates will be ballpark, there are like 30 different heads from Edelbrock alone that will fit my engine.
      Sorry for the long post, but I value your inputs.
      Paul
