      Waverly, Kansas
      New centerforce DF noise
      I installed a new centerforce DF clutch, pressure plate and TO bearing last November in my 69 camaro. At the time, I also installed a freshly rebuilt Muncie 4sp and new flywheel. It's 10 mos later and I finally got the car running. When I barely push the clutch in (when the TO bearing hits the pressure plate), it makes a strange noise. I haven't done more than pull it forward and backward a couple of times (still have engine leaks to correct). Is this noise something that I should be concerned with right away or is it something that may go away after a little use. I know the centerforce uses weights to help clamp the clutch so don't know if that is attributing to the noise or not. Everything is new - so I am confused. Oh, it shifts and moves forward / back just fine. Thanks in advance guys
      Dec 2002
      Lost Wages, Nevada
      What kind of noise is it exactly ??
      Id hate to just guess.........
      Waverly, Kansas
      Kind of a loud "rolling" noise. The closest thing I can think of is the sound of metal rolling on metal (i.e. train wheels on a track) but of course not as loud. This is not a squeek or squeel like metal sliding across metal or something eating itself up.
