    Results 1 to 10 of 10
    Thread: Need A Vent
      SoCal
      Need A Vent
      I'm building a console for my car, and am running the A/C through it to the back seat. So, I need a vent in the rear of the conosle. I had planned to cut slots in the end of the MDF for this, but it didn't work out and the thin slots are not strong enough. So, my next idea is to cut the area where the vent is out completely, and then screw a piece of metal on the outside that has slots in it for the air to flow. It will be a pretty simple design, about 4" across and 3" high, with slots for the air and some screw holes. Does anyone know where I can get something like this made, or can anyone here make it?
      Mar 2004
      Mid-Michigan
      Hey Tom, why don't you take a stroll through a 'yard and pick out some cool looking A/C vents from other cars... Mount those in the back of your console and the rear seat passengers will then be able to control airflow direction and amount with the vents. Do some digging and you will also find some hose and adapters to hook 'em up.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Mar 2002
      North California
      Tom,
      I saw these over at billit specialties,kind of on the $$ side,
      but very nice...The 68 is looking awesome! the new sub box
      looks amazing! Keep up the great work tom.
      Billits Vents 2 1/2 in size...
      http://www.billetspecialties.com/
      SoCal
      Hey Mark, that's an idea although I don't even know where there is a pick-a-part around here. Jim, thanks for the suggestion - I like those vents even though I was planning on a rectangular opening - I could go round instead although I would need to step down from a 3" vent hose.
      Mar 2004
      Mid-Michigan
      I would try to match what is in the dash now just to keep the theme going... eBay may be a good start for vents or even one of the aftermarket guys are supplying them now... Put the new ones in the dash and the older ones in back where they aren't as visible...
      Mark
      Mark:
      El Dorado Hills, CA
      I second ebay, you should be able to find a good selection of vents there for pretty cheap. You might look at something like a Honda center console, I know they have vents in the console you could always use those for example..... I am hooking mine up too, mine are from a LS430 Lexus... Got from Ebay
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Bedford TX
      Some lexus rear vents out of a rx330 would be good there about the size you need and its two vents in one so if you just happen to have two rear passengers they can each have there own vent.
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
      El Dorado Hills, CA
      Exactly what Justin said, the RX330 is a good donor car for vents, also the Acura MDX......
      Brad
      El Dorado Hills, CA
      Here is my console with A/C vents for the rear passengers...
      Brad
      Oct 2003
      South Lyon, MI
      Did you see the vents on the Yellow chevy on DSE's web page? Look about what you are looking for. Might call them to see where they got them.
      Kevin
