Results 1 to 1 of 1
Thread: Power Steering Options
09-09-2006 #1
Hey guys,
I'm getting sick and tired of my old power steering setup. It is the stock Chevy setup but with March serpentine pulleys installed. I can't seem to keep the dang pump from leaking. Seems even if I put a brand new pump to resevoir o-ring in, it'll leak in a matter of time. So I was just wondering if there are any companies out there that make a different setup than the old Chevy power steering setup but that will still bolt up to the stock location. I want to be able to still use all of my other pulleys, just basically replace the pump with a newer design and maybe have to buy the one new pulley for the power steering pump! As sits, I only run the alternator, water pump, crank, and power steering March pulleys. Help! I'm tired of running armstrong steering when my pump runs dry!
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
