Results 1 to 12 of 12
09-02-2006 #1
- Aug 2004
- Rowlett Tx.
- 201
Shroud to Radiator Seal: How Critical?
I'm installing a MarkVIII fan/shroud combo on a 4-row brass radiator in my 68 Chevy truck.
The 'heighth' of the shroud is about .50" taller than the radiator core. It would look best flush @ the top but then there's a .50" gap @ the bottom, or I can split the difference w/about a .250" gap on top & bottom.
How critical is the seal between the 2 pieces? I don't want to negate the benefits of the cooling system upgrades by not considering the smaller details. If I went flush @ the top, what would work to seal the gap @ the bottom w/o getting sucked up from the forces of the fan moving air?
Thanks in advance for any related input.... Scot.
09-06-2006 #2
- Oct 2003
- 277
I wouldn't recommend having any air gaps. Air will always take the path of the least resistance.
09-07-2006 #3
- Aug 2004
- Rowlett Tx.
- 201
I split the difference & once it was tightened down, there's maybe .125" gap on top/bottom.
What can I use to seal up the entire shroud to the radiator?
09-08-2006 #4
