Results 1 to 11 of 11
Thread: How much to cut off??
09-02-2006 #1
I was wondering if anyone knew any rule of thumb measurements for cutting your coil springs, sorta like if you cut so many inches off the coil it will drop the front about x amount of inches, I have moroso trick springs up front and am looking for a 2 inch drop, if anyone knows around how much i should cut so im not cutting, putting back in and recutting that would be great. thanks
09-02-2006 #2
- May 2005
- St. Augustine, FL
- 1,529
There is no exact science. The smartest way to do it is going to be cutting some a test fitting it to see how much it lowered it. I say cut 1 full coil at a time. Dont forget the more you cut the coil the rougher the ride will be.
Andrew Petty
09-02-2006 #3I thought you were only suppossed to cut 1/4 coil at a time. You can't add it back after all.
09-02-2006 #4
- May 2005
- St. Augustine, FL
- 1,529
Depending on how low you want to go that would take forever. I guess you could play it safe and do 1/2 coil at a time.
Originally Posted by nancejd
Andrew Petty
09-02-2006 #5
