    Results 1 to 11 of 11
      Delaware, OH
      Different length rear sway bars?
      I recently installed a MagnaFlow stainless exhaust kit on my Nova. When installing the tail pipes they interferred with the Hotchkis sway bar dog bones. Since at the time I needed an exhaust system worse than a rear sway I temporarily removed it.
      My question is, are there companies that offer different length rear sways? I need to move the dog bone mounts out toward the wheels about 4" on each side to clear the tail pipes. The Hotchkis sway is not long enough to allow that.
      Thanks!
      Oct 2003
      Arvada, Co
      What about splicing in a length in the middle of your current bar? That would change roll stiffness a little though. What about Speedway Engineering? http://www.mspmall.com/speedway/catalog.htm
      Brian
      Delaware, OH
      Thanks Brian, I'll check them out.
      Central CA USA
      Look into cold bending the arms out a bit. It won't affect the heat treat that way. It's more difficult with the hollow bar type since you don't want to kink the tube.
      Sep 2001
      Accord, NY
      Are the Novas that different from a first gen camaro that they even need a rear sway bar?
      68 camaro - SOLD
      CHICAGO SUBURBS
      I've installed a couple Hotchkiss rear bars and they both wouldn't clear the exhaust. One I turned the links around and it barely cleared. The other needed different tail pipes. I don't know why they attach them to the floorpans different than any car had stock? FRANK
      Delaware, OH
      Quote Originally Posted by Rick Dorion
      Rick I'd heard that 1st-gen Camaros and 3rd-gen Novas didn't need a rear sway which is why it didn't concern me to remove it due to the exhaust. The first corner I threw it in to told me otherwise. The body sway was horrible, better than stock due to the front Hotchkis sway, but NO where near as good as it handled with the rear sway.
      Mar 2002
      Redwood City, CA
      Dan, two things. What's the exit location on the mufflers, and have you tried running without the rear swaybar? You might get a bit better handling without the rear bar, according to many sources. With the exhaust, I've seen a few different exit locations on some kits. The exit usually depends on what the car they developed the kit on had installed when they got it. Same goes for certain chassis parts.
      Allen Ortega
      Delaware, OH
      Quote Originally Posted by zbugger
      Allen, The mufflers are center exit. If they had been offset in either direction the dog bones might've cleared. See my previous reply to Rick concerning running the car w/o a rear sway. I couldn't believe the difference. It definitely needs the rear sway.
      Central CA USA
      Take a look at a 3rd gen rear bar, it's probably wider.
      Delaware, OH
      Quote Originally Posted by David Pozzi
      Thanks David, I'll check them out.
