    Thread: Fire Fire Fire
      florida
      Fire Fire Fire
      long story short my wife's blazer went up in flames today. UNfortunately i put the fire when i should have let this P.O.S. burn to the ground. anyway. got lucky (snicker snicker) and there was no major damage. except for the fuel injector spider. all of the nylon fuel tubing that runs from the injectors to the poppet valves melted. does anyone know where i can get this stuff? its 3/16 O.D black nylon. i went to the local parts stores but all i got was blank stares and "I Guess youll have to spend 300 dollars on a new spider assembly.
      Tough guys may wear pink, but Bad Asses still wear black.
      Oct 2003
      Arvada, Co
      Junk yard?
      Brian
      Cumberland, Maryland
      blazer...fire...anyone see the irony?
      Feb 2006
      Boulder, Colorado
      My first car was a 1980 Blazer. It caught on fire after the crappy rebuilt Holley I bought from Summit shot fuel out of the top of the bowl due to metal shavings inside everything - needle/seats, etc. Like the dumba$$ 16 year-old I was, I ran to the garden hose to put it out. Then, I tried to restart the truck, shooting water out of the exhaust and cracking both heads and bending 2 rods. Smart! 2 years of washing dishes to buy the truck, and 1 more year slopping texmex to pay for the engine rebuild. But I learned 2 priceless lessons:
      1. How to tear down and rebuild a motor
      2. I never buy ANYTHING from Summit. Still.
      Good luck, I would hit the junk yards.
      Eric
      69 Camaro - LT1 w/ 700R4, DSE springs, swaybar and Konis. Still rockin' it old school with 15" wheels and 60 series tires.
      Ebay
      Fairly common problem with those damned spider injection setups, I've seen problems with several of them at my work. Expensive little things too, but I'd highly recommend you avoid a junkyard unit...you could have another fire very quickly.
      st peters ,missouri
      Do the fuel log while you are in there.
      Jun 2005
      I realize this is an older thread but the tubing you are looking for is available from Eastwood. If they have it I am sure it is available elsewhere for less.
      Eric
      68 Mustang Coupe EFI 302 | 94 Mustang GT | 08 G8GT
