      Batesville, IN
      '89 Mustang - Cobra Rear Disc
      I just ordered a complete kit from North Race Cars that uses the Cobra rear discs (11.65") for the rear of my '89 coupe. I also bought a '93 Cobra master cylinder. For now I'm going to run the stock SN95 front setup, but maybe someday update to the the Dual Pistion PBR's on front.
      If anyone has used this setup, please feel free to give me your thoughts and/or suggestions for the install (I don't think it will be too difficult). Also, if you are using this setup, did you install an adjustable proportioning valve?
      I know late model Mustangs aren't all the craze on here, but I thought I'd see if anyone was tinkering with one. It's the only project that I've managed to get on the road so far!
      Later,
      Brandon
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Whittier, CA
      i have used those brackets and the 11.65 cobra brakes. the brackets were a little bit crooked and took some "massaging" of the brake caliper to make them fit well. Also i used stock length 5 lug axles and has to make a spacer to center the rotor on the hub. no big deal, just extra work.
